주요 콘텐츠로 건너뛰기
Garmin Drive 60LM Speaker Replacement
필요한 것
  1. Garmin Drive 60LM Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Garmin Drive 60LM Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Speaker Replacement: 2 단계, 이미지 1/3 Garmin Drive 60LM Speaker Replacement: 2 단계, 이미지 2/3 Garmin Drive 60LM Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the back panel using the metal spudger tool.
    • You will not be able to remove the back panel entirely. Make sure to separate the back panel slowly so that you do not rip the orange ribbon inside.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Speaker Replacement: 3 단계, 이미지 1/3 Garmin Drive 60LM Speaker Replacement: 3 단계, 이미지 2/3 Garmin Drive 60LM Speaker Replacement: 3 단계, 이미지 3/3
    • Use a plastic spudger tool to lift the wires from behind the motherboard.
    • Carefully disconnect the wires attaching the speaker to the motherboard using your fingers.
  4. Garmin Drive 60LM Speaker Replacement: 4 단계, 이미지 1/2 Garmin Drive 60LM Speaker Replacement: 4 단계, 이미지 2/2
    • Using a plastic spudger and your fingers, remove the speaker from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andy Flores
회원 가입일: 01/30/17
238 평판
안내서 2개 작성하였습니다
Baylor, Team 3-3, Whitney Spring 2017 Baylor, Team 3-3, Whitney Spring 2017 회원
BU-WHITNEY-S17S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 498
