소개
To replace the speaker in your device you will need a T4 Torx screwdriver, a metal spudger, a plastic spudger, and a replacement speaker. Be sure to have a large workspace to avoid mishandling or damaging the device components.
필요한 것
Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
