소개
If there is an issue with your Garmin 1000 Edge (M/N F4ACGQ00) mount, use this guide to replace the back cover of your unit.
The back cover houses the device’s SIM card and battery as well. This guide can be used to gain access to these components as needed.
필요한 것
Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
Pull the front side of the device apart from the back side.
다른 한 분이 해당 안내서를 완성하였습니다.
