주요 콘텐츠로 건너뛰기
Garmin Edge 1000 Lithium-Ion Battery Replacement
필요한 것
  1. Garmin Edge 1000 Lithium-Ion Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Garmin Edge 1000 Lithium-Ion Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Lithium-Ion Battery Replacement: 2 단계, 이미지 1/2 Garmin Edge 1000 Lithium-Ion Battery Replacement: 2 단계, 이미지 2/2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Lithium-Ion Battery Replacement, Lithium-Ion Battery: 3 단계, 이미지 1/2 Garmin Edge 1000 Lithium-Ion Battery Replacement, Lithium-Ion Battery: 3 단계, 이미지 2/2
    • Using the nylon spudger, pry the battery off of the back half of the device. Pull the battery away from the back cover.
    • Cut the two wires that connect the back cover to the battery using a pair of wire cutters.
  4. Garmin Edge 1000 Lithium-Ion Battery Replacement: 4 단계, 이미지 1/1
    • Strip the ends of the red and silver wires connected to the back panel of the device using a pair of wire strippers.
  5. Garmin Edge 1000 Lithium-Ion Battery Replacement: 5 단계, 이미지 1/1
    • Solder the silver wire from the new battery with the silver wire connected to the back panel of your device.
    • Repeat these steps with the red wire from the new battery and the wire from the back panel.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor McNees
회원 가입일: 10/03/19
558 평판
안내서 4개 작성하였습니다
댓글 한 개
Hi Taylor, which battery (Voltage, size) did you use and where did you buy it? Is it a Lithium-Polymer? Thanks for letting me know. Btw, maybe not the best way to cut both battery wires, plus and minus, at the same time, as it short circuits the probably still working battery.
Klaus S. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 101
전체 시간: 5,425
