주요 콘텐츠로 건너뛰기
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
필요한 것
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: 1 단계, 이미지 1/2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: 1 단계, 이미지 2/2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: 2 단계, 이미지 1/2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: 2 단계, 이미지 2/2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: 3 단계, 이미지 1/3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: 3 단계, 이미지 2/3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: 3 단계, 이미지 3/3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Taylor McNees
회원 가입일: 10/03/19
558 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 20
전체 시간: 1,536
