주요 콘텐츠로 건너뛰기
Garmin Edge 830 Motherboard Replacement
필요한 것
  1. Garmin Edge 830 Motherboard Replacement, Touch Display: 1 단계, 이미지 1개 중 1개
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
  2. Garmin Edge 830 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
  3. Garmin Edge 830 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Garmin Edge 830 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
결론
작성자
6다른 기여자 명과 함께
Alden Gibbs
회원 가입일: 03/21/22
265 평판
안내서 3개를 작성함
1가이드 댓글
Hi, i have an issue with Garmin Edsge 830; the problem is that the device cant connect to the phone and the official statemenet from Garmin was that the bluetooth sensor is not working. Is there a way to reapir it? i guess it is soldered on the motherboard, meaning i should change the whole motherboard?
Thanks for the answer
Jan Žužek - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 32
전체 시간: 614
