주요 콘텐츠로 건너뛰기
Garmin Fenix 2 Battery Replacement
필요한 것
  1. Garmin Fenix 2 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Garmin Fenix 2 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Garmin Fenix 2 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  2. Garmin Fenix 2 Battery Replacement: 2 단계, 이미지 2개 중 1개 Garmin Fenix 2 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  3. Garmin Fenix 2 Battery Replacement: 3 단계, 이미지 2개 중 1개 Garmin Fenix 2 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brandon Barger
회원 가입일: 02/13/16
1,219 평판
안내서 5개를 작성함
IUPUI, Team 54-4, Wilson Spring 2016 IUPUI, Team 54-4, Wilson Spring 2016 회원
IUPUI-WILSON-S16S54G4
3 회원들
안내서 7개를 작성함
7가이드 댓글
can you tell us exactly which battery should be used? Thanks in advance!
fabrizionannini - 답글
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
homanchris -
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
https://buy.garmin.com/en-US/US/into-spo...
L P -
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
L P - 답글
After some research on eBay the correct battery size should be PD3555 3.7V which is 500mAh.
Yang - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 38
지난 30일: 193
전체 시간: 35,121
