소개
We will remove the display from the Garmin watch so it can be replaced. Tools that you will need include nylon spudger and Torx T9 screwdriver.
필요한 것
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
Good information, but :
- spudger not really needed, nail is enough.
- missing the one regarding the need for a soldering iron ! The old battery needs to be unsoldered and the new one soldered to the inside wiring. Not so difficult but soldering iron needed !
Got a spare battery on eBay (vendor is http://akku-wechsel.de). Delivery was very fast. After replacement I went from 6~8 hours life to 3~4 weeks :) So happy with the upgrade !
Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
This screw is smaller than the .8mm, and cannot be removed with the Torx T9 screwdriver
다른 한 분이 해당 안내서를 완성하였습니다.
