주요 콘텐츠로 건너뛰기
Garmin Fenix 3 Display Assembly Replacement
필요한 것
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2개 중 1개 Garmin Fenix 3 Display Assembly Replacement, Display Assembly: 1 단계, 이미지 2개 중 2개
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Display Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Display Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Display Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Set the watch face aside.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adam Estabrook
회원 가입일: 09/07/18
1,131 평판
안내서 5개를 작성함
4가이드 댓글
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - 답글
I have the same question.
Nicolas Chartier -
How do you make sure ribbon connector is aligned correctly
Steven - 답글
I have Fennix3, replaced the battery with new one (tested the battery before fixing), however, after complete assembly the watch does not start up? any hints?
Abdullah - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 67
전체 시간: 10,368
