주요 콘텐츠로 건너뛰기
Garmin Fenix 3 HR Battery Replacement
필요한 것
  1. Garmin Fenix 3 HR Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Garmin Fenix 3 HR Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: 2 단계, 이미지 3개 중 1개 Garmin Fenix 3 HR Battery Replacement: 2 단계, 이미지 3개 중 2개 Garmin Fenix 3 HR Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: 4 단계, 이미지 2개 중 1개 Garmin Fenix 3 HR Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: 7 단계, 이미지 1개 중 1개
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Now attach the new battery with adhesive and reassemble.
결론
다른 42명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Victor Tanguy
회원 가입일: 03/26/18
1,383 평판
안내서 1개를 작성함
IUPUI, Team S1-G6, Harley Spring 2018 IUPUI, Team S1-G6, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G6
3 회원들
안내서 5개를 작성함
29가이드 댓글
Does anybody do It in a fenix 5?
Fernando Alcaraz - 답글
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - 답글
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 86
지난 30일: 423
전체 시간: 74,541
