주요 콘텐츠로 건너뛰기
Garmin Fenix 3 HR Motherboard Replacement
필요한 것
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: 2 단계, 이미지 1/2 Garmin Fenix 3 HR Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: 4 단계, 이미지 1/2 Garmin Fenix 3 HR Motherboard Replacement: 4 단계, 이미지 2/2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: 5 단계, 이미지 1/1
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: 6 단계, 이미지 1/1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: 7 단계, 이미지 1/1
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: 8 단계, 이미지 1/1
    • Now attach battery to new motherboard and reassemble.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jacob Smiley
회원 가입일: 03/26/18
277 평판
안내서 1개 작성함
IUPUI, Team S1-G6, Harley Spring 2018 IUPUI, Team S1-G6, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G6
3 회원들
안내서 4개 작성하였습니다
댓글 2개
And where would one source replacement motherboard?
jonathan.hatchuel - 답글
donde puedo encontras placa.madre reeemplazo????
luis zavala - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 29
전체 시간: 4,779
