주요 콘텐츠로 건너뛰기
Garmin Fenix 3 Motherboard Replacement
필요한 것
  1. Garmin Fenix 3 Motherboard Replacement, Display Assembly: 1 단계, 이미지 2개 중 1개 Garmin Fenix 3 Motherboard Replacement, Display Assembly: 1 단계, 이미지 2개 중 2개
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Set the watch face aside.
  5. Garmin Fenix 3 Motherboard Replacement, GPS Antenna: 5 단계, 이미지 1개 중 1개
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully remove the antenna, and set it aside.
  7. Garmin Fenix 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 Garmin Fenix 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 Garmin Fenix 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Locate the two silver 1.4 mm T5 screws, and carefully unscrew them.
    • To avoid losing or dropping the screws once they are loose, use tweezers to extract them.
  8. Garmin Fenix 3 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Garmin Fenix 3 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the watch and turn it over one hand. The motherboard should fall out easily.
    • When reinserting your motherboard, slide it in instead of pressing it. The motherboard must go beneath a lip at the base of the watch body.
  9. Garmin Fenix 3 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Using the spudger, separate the motherboard from the battery, which are both held together with a mild adhesive.
  10. Garmin Fenix 3 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Motherboard without metal cover
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Adam Estabrook
회원 가입일: 09/07/18
1,131 평판
안내서 5개를 작성함
18가이드 댓글
Hello,
i’m looking for replacement of start/stop button micro switch. Do you know what is the switch number which i can look for?
Thank you
Jan Stefan - 답글
that's my problem too and i can't find any solution.
Hamidmonti -
How did you remove the metal cover from the moterboard (last picture)
slowrun - 답글
Where can I find a replacement Motherboard ? None of my buttons are responding and I can’t even do a Factory reset.
All that works is switching off and back on.
arnaud.lhote - 답글
I have exact same issue. I sent my watch to official repair service to Split (Croatia) and they said they aren’t able to fix it. I can see only main screen of the watch, buttons don’t respond at all. Would like to know how to fix the issue.
ilija.veselica -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 115
전체 시간: 10,864
