주요 콘텐츠로 건너뛰기
Garmin Fenix 3 Wrist Strap Replacement
필요한 것
  1. Garmin Fenix 3 Wrist Strap Replacement, Wrist Strap: 1 단계, 이미지 1/1
    • Identify the screws near the bases of two wrist straps.
  2. Garmin Fenix 3 Wrist Strap Replacement: 2 단계, 이미지 1/1
    • Hold one screwdriver firmly in one hand, as demonstrated in the image.
  3. Garmin Fenix 3 Wrist Strap Replacement: 3 단계, 이미지 1/1
    • Secure the watch in the same hand, positioning the screwdriver over the screw.
  4. Garmin Fenix 3 Wrist Strap Replacement: 4 단계, 이미지 1/1
    • Once the watch is secure, insert the screwdriver into the screw, and hold firmly.
  5. Garmin Fenix 3 Wrist Strap Replacement: 5 단계, 이미지 1/1
    • With the watch and the first screwdriver secure, insert the second screwdriver into the opposite screw.
    • Holding the first screwdriver firmly, unscrew using the second screwdriver.
  6. Garmin Fenix 3 Wrist Strap Replacement: 6 단계, 이미지 1/1
    • Remove the bar from the wrist strap to release.
    • Depending on which side the bar is inserted, you may end up loosening the screw instead of the bar. Keep this in mind to avoid losing your screws.
  7. Garmin Fenix 3 Wrist Strap Replacement: 7 단계, 이미지 1/1
    • Repeat this process for the other side, adjusting the position of the watch accordingly.
결론
Adam Estabrook
회원 가입일: 09/07/18
1,057 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 21
전체 시간: 3,681
