주요 콘텐츠로 건너뛰기
Garmin Forerunner 25 Battery Replacement
필요한 것
  1. Garmin Forerunner 25 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: 2 단계, 이미지 1/1
    • Pry the old battery out using a plastic spudger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dustin Persohn
회원 가입일: 03/21/18
235 평판
안내서 2개 작성하였습니다
IUPUI, Team S5-G3, Baechle Spring 2018 IUPUI, Team S5-G3, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G3
3 회원들
안내서 5개 작성하였습니다
댓글 11개
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - 답글
I need to know as well. What kind of battery is it? PD…????
girlie_360 - 답글
Just look at the last picture. PD2430C1
Leandro Lind - 답글
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - 답글
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 33
30일 전: 107
전체 시간: 6,060
