주요 콘텐츠로 건너뛰기
Garmin Forerunner 25 Motherboard Replacement
필요한 것
  1. Garmin Forerunner 25 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Motherboard Replacement: 2 단계, 이미지 1/1
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Motherboard Replacement: 5 단계, 이미지 1/1
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dustin Persohn
회원 가입일: 03/21/18
235 평판
안내서 2개 작성하였습니다
IUPUI, Team S5-G3, Baechle Spring 2018 IUPUI, Team S5-G3, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 792
