주요 콘텐츠로 건너뛰기
Garmin Forerunner 25 Screen Replacement
필요한 것
  1. Garmin Forerunner 25 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Screen Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
  6. Garmin Forerunner 25 Screen Replacement, Screen: 6 단계, 이미지 1개 중 1개
    • Remove gold piece in the corner using the pointed side of the 4 spudger.
    • Any spudger with a pointed end should work to remove this piece.
  7. Garmin Forerunner 25 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Pry the screen up with a plastic opening tool.
    • Any plastic tool with a flat edge should work to remove the screen.
    • Remove the screen.
결론
작성자
2다른 기여자 명과 함께
Suzanne Drumm
회원 가입일: 03/21/18
85 평판
안내서 1개를 작성함
IUPUI, Team S5-G3, Baechle Spring 2018 IUPUI, Team S5-G3, Baechle Spring 2018 회원
IUPUI-BAECHLE-S18S5G3
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 1,868
