주요 콘텐츠로 건너뛰기
Garmin Forerunner 25 Watchband Replacement
  1. Garmin Forerunner 25 Watchband Replacement, Starting pieces: 1 단계, 이미지 2개 중 1개 Garmin Forerunner 25 Watchband Replacement, Starting pieces: 1 단계, 이미지 2개 중 2개
    • Assemble the watch with the broken wristband, along with the replacement parts. I don't have many specific suggestions here. I just googled watchband replacement for the Garmin Forerunner 25 and found this package for $6.99 on Amazon. It came with the small screwdrivers you will need to swap out the wristband, so I considered this a good price.
  2. Garmin Forerunner 25 Watchband Replacement, Remove watchband using screwdriver: 2 단계, 이미지 2개 중 1개 Garmin Forerunner 25 Watchband Replacement, Remove watchband using screwdriver: 2 단계, 이미지 2개 중 2개
    • Pretty simple, but insert one screwdriver on either side and hold one in place while loosening the other side (lefty loosey, rightey tightey). It takes more turning than initially expected, but comes apart eventually into two interlocking screws.
  3. Garmin Forerunner 25 Watchband Replacement, Insert new watch band: 3 단계, 이미지 2개 중 1개 Garmin Forerunner 25 Watchband Replacement, Insert new watch band: 3 단계, 이미지 2개 중 2개
    • Align new watch band, insert the screws, and do the inverse of what you did to tighten the screws through the watchband, rightey tightey.
  4. Garmin Forerunner 25 Watchband Replacement, Repeat on other watchband to finish the job.: 4 단계, 이미지 2개 중 1개 Garmin Forerunner 25 Watchband Replacement, Repeat on other watchband to finish the job.: 4 단계, 이미지 2개 중 2개
    • Repeat the same removal and replacement steps on the other side. This was my first time doing it, and as you can see from the timing on the watch it took me less than 15 minutes total. New silicone band is quite comfortable and sturdy. In all, it took about 5 days for the band to be delivered and $6.99 total, plus 15 mins to replace myself.
결론
작성자
1다른 기여자 명과 함께
Nathan Scinto-Madonich
회원 가입일: 01/08/23
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 25
전체 시간: 993
