주요 콘텐츠로 건너뛰기
Garmin Forerunner 945 Screen Replacement
필요한 것
  1. Garmin Forerunner 945 Screen Replacement, Realize you need a new screen and order one: 1 단계, 이미지 1개 중 1개
    • You can find replacement screens on eBay and amazon. I paid $40 plus tax. If you want to skip all these instructions, Garmin offered to replace mine for $160...I kindly declined.
  2. Garmin Forerunner 945 Screen Replacement, Apply heat to warm up the glue: 2 단계, 이미지 1개 중 1개
    • I used a hairdryer on max heat. Went around all the edges of the screen for about 2 minutes. I was careful to avoid the bands since they are rubber.
  3. Garmin Forerunner 945 Screen Replacement, Remove old screen with razor: 3 단계, 이미지 1개 중 1개
    • Take your time here. I would wiggle and pry slowly until I caught a ledge. Then slowly pulled up while working the razor around.
  4. Garmin Forerunner 945 Screen Replacement, Disconnect the two ribbon cables: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers here and be careful to not poke any other components.
  5. Garmin Forerunner 945 Screen Replacement, Remove remaining glue with tweezers: 5 단계, 이미지 1개 중 1개
    • The picture shows the glue after it hardened and I had already taken it out. If it feels really stuck, apply a but more heat. Once you get a good portion out you can use that as a handle and slowly lift the rest out.
  6. Garmin Forerunner 945 Screen Replacement, (Optional) remove NFC antenna: 6 단계, 이미지 2개 중 1개 Garmin Forerunner 945 Screen Replacement, (Optional) remove NFC antenna: 6 단계, 이미지 2개 중 2개
    • Depending on if your replacement came with this black piece (mine did not), you may want to use this on your new screen. I used tweezers to gently peel it off and stick on the new screen. Just make sure you see exactly where it is placed before removing because the ribbon cable connectors need to align properly.
  7. Garmin Forerunner 945 Screen Replacement, Connect the ribbon cables from new screen: 7 단계, 이미지 1개 중 1개
    • This was the longest step for me. The NFC connector (black) is really small and hard to get on the dock. Use good lighting and patience and a plastic tool. Some guides say to apply glue first but it took me a while to get this part on. Im glad I waited till after to apply glue
  8. Garmin Forerunner 945 Screen Replacement, Apply glue to inner bezel: 8 단계, 이미지 1개 중 1개
    • Picture here shows cable disconnected but connect it first. While holding the screen in one hand, apply B7000 glue all around the ledge. Wear gloves to prevent it from getting on your hands. Apply more glue than you think you need. Then firmly press the screen down in place. Remove excess glue from the outside with an alcohol wipe.
    • B7000 says 2 hours minimum and 24 hours for full cure. And now your done!
결론
Done!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Will Mondet
회원 가입일: 01/22/21
262 평판
안내서 1개를 작성함
5가이드 댓글
Hallo! Muss bei diesen Lufteinschlüssen das Display getauscht werden, oder reicht eine neuerliche Verklebung aus?
Lg Michael
Michael S. - 답글
The screen replacements usually come with the display and glass together. I don’t know if they are sold separately.
Will Mondet -
Hallo, hat jemand getestet ob die Uhr danach wirklich wasserdicht ist?
Danke schon mal im Voraus
Ariane
Ariane - 답글
Meiner funktioniert gut unter Wasser nach der Reparatur
Will Mondet -
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 167
지난 30일: 731
전체 시간: 5,394
