주요 콘텐츠로 건너뛰기
Garmin GPSmap 60CSx Gasket Replacement
필요한 것
  1. Garmin GPSmap 60CSx Gasket Replacement, Back Cover and AA Batteries: 1 단계, 이미지 1/1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Gasket Replacement: 2 단계, 이미지 1/1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Gasket Replacement: 3 단계, 이미지 1/2 Garmin GPSmap 60CSx Gasket Replacement: 3 단계, 이미지 2/2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Gasket Replacement, Gasket: 4 단계, 이미지 1/2 Garmin GPSmap 60CSx Gasket Replacement, Gasket: 4 단계, 이미지 2/2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Separate the back panel from the front.
  5. Garmin GPSmap 60CSx Gasket Replacement: 5 단계, 이미지 1/2 Garmin GPSmap 60CSx Gasket Replacement: 5 단계, 이미지 2/2
    • Remove the gasket.
    • Be careful to make sure the gasket is aligned correctly to ensure it is water proof.
결론
Samantha Shelton
회원 가입일: 04/05/18
188 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 25
전체 시간: 1,645
