주요 콘텐츠로 건너뛰기
Garmin Nuvi 1390LMT Battery Replacement
필요한 것
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 1390LMT Battery Replacement: 2 단계, 이미지 2/2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: 3 단계, 이미지 1/1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: 4 단계, 이미지 1/2 Garmin Nuvi 1390LMT Battery Replacement: 4 단계, 이미지 2/2
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: 5 단계, 이미지 1/1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: 6 단계, 이미지 1/2 Garmin Nuvi 1390LMT Battery Replacement: 6 단계, 이미지 2/2
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: 7 단계, 이미지 1/1
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: 8 단계, 이미지 1/2 Garmin Nuvi 1390LMT Battery Replacement: 8 단계, 이미지 2/2
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Trey Ulsh
회원 가입일: 10/22/15
537 평판
안내서 3개 작성하였습니다
Montana Tech, Team 10-4, Shirk Fall 2015 Montana Tech, Team 10-4, Shirk Fall 2015 회원
MTUM-SHIRK-F15S10G4
5 회원들
안내서 3개 작성하였습니다
댓글 한 개
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 28
전체 시간: 3,766
