주요 콘텐츠로 건너뛰기
Garmin Nuvi 1390LMT Logic Board Replacement
필요한 것
  1. Garmin Nuvi 1390LMT Logic Board Replacement, Logic Board: 1 단계, 이미지 1/1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Logic Board Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 1390LMT Logic Board Replacement: 2 단계, 이미지 2/2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Logic Board Replacement: 3 단계, 이미지 1/1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Logic Board Replacement: 4 단계, 이미지 1/1
    • Gently pull the wire ribbon connecting the screen to the logic board from the plug.
    • Be careful when unplugging the wire ribbon. It is very fragile.
  5. Garmin Nuvi 1390LMT Logic Board Replacement: 5 단계, 이미지 1/1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Logic Board Replacement: 6 단계, 이미지 1/1
    • Flip the logic board over.
  7. Garmin Nuvi 1390LMT Logic Board Replacement: 7 단계, 이미지 1/2 Garmin Nuvi 1390LMT Logic Board Replacement: 7 단계, 이미지 2/2
    • Disconnect the harness between the battery and the logic board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Trey Ulsh
회원 가입일: 10/22/15
537 평판
안내서 3개 작성하였습니다
Montana Tech, Team 10-4, Shirk Fall 2015 Montana Tech, Team 10-4, Shirk Fall 2015 회원
MTUM-SHIRK-F15S10G4
5 회원들
안내서 3개 작성하였습니다
댓글 한 개
I need a replacement board for My Garmin Nuvi 1490LMT - where can I get one?
Danny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 934
