주요 콘텐츠로 건너뛰기
Garmin Nuvi 1490T Display Screen Replacement
필요한 것
  1. Garmin Nuvi 1490T Display Screen Replacement, Front Frame Panel: 1 단계, 이미지 1개 중 1개
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Display Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Display Screen Replacement: 3 단계, 이미지 2개 중 1개 Garmin Nuvi 1490T Display Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: 4 단계, 이미지 3개 중 1개 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: 4 단계, 이미지 3개 중 2개 Garmin Nuvi 1490T Display Screen Replacement, Second Frame Panel: 4 단계, 이미지 3개 중 3개
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Display Screen Replacement: 5 단계, 이미지 3개 중 1개 Garmin Nuvi 1490T Display Screen Replacement: 5 단계, 이미지 3개 중 2개 Garmin Nuvi 1490T Display Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Display Screen Replacement, Display Screen: 6 단계, 이미지 3개 중 1개 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: 6 단계, 이미지 3개 중 2개 Garmin Nuvi 1490T Display Screen Replacement, Display Screen: 6 단계, 이미지 3개 중 3개
    • Gently lift up the display screen using your fingers to make sure the only thing connecting it to the body is the ribbon cable.
  7. Garmin Nuvi 1490T Display Screen Replacement: 7 단계, 이미지 2개 중 1개 Garmin Nuvi 1490T Display Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the piece of tape that is covering the connecting point of the motherboard and display.
  8. Garmin Nuvi 1490T Display Screen Replacement: 8 단계, 이미지 3개 중 1개 Garmin Nuvi 1490T Display Screen Replacement: 8 단계, 이미지 3개 중 2개 Garmin Nuvi 1490T Display Screen Replacement: 8 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using the plastic opening tool or your fingers, lift up the ZIF connector holding the ribbon cable in place.
    • Carefully pull the ribbon cable out of the connector with tweezers or two fingers.
    • Gently disconnect the display by pulling upward. Set display aside.
    • If the display screen does not disconnect easily, make sure the ZIF connector is no longer holding it in place.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ricardo Solis
회원 가입일: 01/20/16
1,058 평판
안내서 6개를 작성함
USF Tampa, Team 15-2, Remmell Spring 2016 USF Tampa, Team 15-2, Remmell Spring 2016 회원
USFT-REMMELL-S16S15G2
4 회원들
안내서 10개를 작성함
1가이드 댓글
Awesome!! Thank you for putting this out there. Helped me save buying a new gps when the screen on my got damaged.
George Gearing - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 27
전체 시간: 2,871
