주요 콘텐츠로 건너뛰기
Garmin Nuvi 1490T Speaker Replacement
필요한 것
  1. Garmin Nuvi 1490T Speaker Replacement, Front Frame Panel: 1 단계, 이미지 1/1
    • Power off your GPS before moving on.
    • Locate the crevice that separates the frame from the body.
  2. Garmin Nuvi 1490T Speaker Replacement: 2 단계, 이미지 1/1
    • Carefully insert the plastic prying tool into the crevice to separate the frame from the body.
    • Applying excessive force can lead to a damaged or scratched display screen.
  3. Garmin Nuvi 1490T Speaker Replacement: 3 단계, 이미지 1/2 Garmin Nuvi 1490T Speaker Replacement: 3 단계, 이미지 2/2
    • Slide the plastic prying tool around the perimeter to completely remove the frame.
  4. Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: 4 단계, 이미지 1/3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: 4 단계, 이미지 2/3 Garmin Nuvi 1490T Speaker Replacement, Second Frame Panel: 4 단계, 이미지 3/3
    • Remove the four 11.0 mm screws using the Torx T5 screwdriver.
  5. Garmin Nuvi 1490T Speaker Replacement: 5 단계, 이미지 1/3 Garmin Nuvi 1490T Speaker Replacement: 5 단계, 이미지 2/3 Garmin Nuvi 1490T Speaker Replacement: 5 단계, 이미지 3/3
    • Using the plastic prying tool, dislodge the frame from the body of the device.
    • Using your hands, completely disconnect the frame from the body.
    • Set the pieces of the frame aside.
  6. Garmin Nuvi 1490T Speaker Replacement, Speaker: 6 단계, 이미지 1/2 Garmin Nuvi 1490T Speaker Replacement, Speaker: 6 단계, 이미지 2/2
    • Carefully move the display out of the way of the speaker revealing the blue and black cord from the speaker.
  7. Garmin Nuvi 1490T Speaker Replacement: 7 단계, 이미지 1/2 Garmin Nuvi 1490T Speaker Replacement: 7 단계, 이미지 2/2
    • Using tweezers, gently clamp onto the white plastic end of the speaker connector.
    • Remove it by pulling slightly towards the speaker.
  8. Garmin Nuvi 1490T Speaker Replacement: 8 단계, 이미지 1/3 Garmin Nuvi 1490T Speaker Replacement: 8 단계, 이미지 2/3 Garmin Nuvi 1490T Speaker Replacement: 8 단계, 이미지 3/3
    • Wedge a nylon spudger into the crevice to begin to dislodge it from the body.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Slide the tool around the perimeter to fully dislodge the speaker.
결론
Ricardo Solis
회원 가입일: 01/20/16
1,037 평판
안내서 6개 작성하였습니다
USF Tampa, Team 15-2, Remmell Spring 2016 USF Tampa, Team 15-2, Remmell Spring 2016 회원
USFT-REMMELL-S16S15G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 251
