주요 콘텐츠로 건너뛰기
Garmin Nuvi 200 Display Replacement
필요한 것
  1. Garmin Nuvi 200 Display Replacement, Rear Casing: 1 단계, 이미지 1/2 Garmin Nuvi 200 Display Replacement, Rear Casing: 1 단계, 이미지 2/2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Display Replacement: 2 단계, 이미지 1/1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Display Replacement: 3 단계, 이미지 1/2 Garmin Nuvi 200 Display Replacement: 3 단계, 이미지 2/2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Display Replacement, Display: 4 단계, 이미지 1/1
    • Apply pressure to the tabs holding the screen in place with the plastic opening tool
  5. Garmin Nuvi 200 Display Replacement: 5 단계, 이미지 1/2 Garmin Nuvi 200 Display Replacement: 5 단계, 이미지 2/2
    • Apply pressure to the same tabs again to remove the front of the screen.
  6. Garmin Nuvi 200 Display Replacement: 6 단계, 이미지 1/2 Garmin Nuvi 200 Display Replacement: 6 단계, 이미지 2/2
    • Peel away the material holding the ribbon cable in place.
    • Peeling the sticker halfway will allow you to access the ribbon cable. Removing it fully will allow you to detach the upper case from the lower case.
  7. Garmin Nuvi 200 Display Replacement: 7 단계, 이미지 1/2 Garmin Nuvi 200 Display Replacement: 7 단계, 이미지 2/2
    • Disconnect the ribbon cable from the logic board.
    • Make sure to disconnect the cable from both ports.
  8. Garmin Nuvi 200 Display Replacement: 8 단계, 이미지 1/2 Garmin Nuvi 200 Display Replacement: 8 단계, 이미지 2/2
    • The display consists of two screens which are held together by the ribbon.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 04/11/10
7 평판
안내서 1개 작성함
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G90
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 10,998
