메인 콘텐츠로 스킵하기
소개
Replacing the speaker in a Garmin Nuvi 200.
  1. Peel off the sticker from the bottom of the device to reveal two screws. Peel off the sticker from the bottom of the device to reveal two screws.
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Remove two T5 Torx screws.
    • Remove two T5 Torx screws.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Insert a plastic opening tool in the gap between the front and rear casing. Carefully work the tool around the gap, separating the two halves of the case.
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  5. Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
  6. Pull the cable out to detach the speaker from the logic board.
    • Pull the cable out to detach the speaker from the logic board.
  7. Wedge the iPod opener into the space between the speaker and the case. Apply pressure to pry the speaker away from the case. Apply pressure to pry the speaker away from the case.
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Anjelica
회원 가입일: 2010년 04월 11일
504 평판
안내서 3개 작성하였습니다
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G90
4 회원들
안내서 9개 작성하였습니다
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - 답글
Where can you buy replacement speakers for the Garmin units?
Brat Fry - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 6,537
