주요 콘텐츠로 건너뛰기
Garmin Nuvi 200W Rear Cover Replacement
필요한 것
  1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: 1 단계, 이미지 1/3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: 1 단계, 이미지 2/3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: 1 단계, 이미지 3/3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200W  Rear Cover Replacement: 2 단계, 이미지 1/1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200W  Rear Cover Replacement: 3 단계, 이미지 1/3 Garmin Nuvi 200W  Rear Cover Replacement: 3 단계, 이미지 2/3 Garmin Nuvi 200W  Rear Cover Replacement: 3 단계, 이미지 3/3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200W  Rear Cover Replacement: 4 단계, 이미지 1/2 Garmin Nuvi 200W  Rear Cover Replacement: 4 단계, 이미지 2/2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
결론
Matthew Eires
회원 가입일: 03/08/17
319 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 UMass Dartmouth, Team S5-G4, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S5G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 252
