주요 콘텐츠로 건너뛰기
Garmin Nuvi 2455LMT Back Panel Assembly Replacement
필요한 것
  1. Garmin Nuvi 2455LMT Back Panel Assembly Replacement, Back Panel Assembly: 1 단계, 이미지 1/1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 3 단계, 이미지 1/3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 3 단계, 이미지 2/3 Garmin Nuvi 2455LMT Back Panel Assembly Replacement: 3 단계, 이미지 3/3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nathaniel Williams
회원 가입일: 09/19/16
264 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 975
