주요 콘텐츠로 건너뛰기
Garmin Nuvi 2455LMT Speaker Replacement
필요한 것
  1. Garmin Nuvi 2455LMT Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver. Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Speaker Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 2455LMT Speaker Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
  3. Garmin Nuvi 2455LMT Speaker Replacement: 3 단계, 이미지 1/3 Garmin Nuvi 2455LMT Speaker Replacement: 3 단계, 이미지 2/3 Garmin Nuvi 2455LMT Speaker Replacement: 3 단계, 이미지 3/3
    • Open the device carefully being weary of the orange band that is going from the screen to the mother board.
  4. Garmin Nuvi 2455LMT Speaker Replacement: 4 단계, 이미지 1/2 Garmin Nuvi 2455LMT Speaker Replacement: 4 단계, 이미지 2/2
    • Using the plastic prying tool, carefully pry the speaker from the plastic backing.
    • Remove the speaker from the motherboard by gently pulling on the wire.
결론
anthony della volpe
회원 가입일: 09/15/16
111 평판
안내서 1개 작성함
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 211
