주요 콘텐츠로 건너뛰기
Garmin Nuvi 2455LMT Touch Screen Replacement
필요한 것
  1. Garmin Nuvi 2455LMT Touch Screen Replacement, Back Panel Assembly: 1 단계, 이미지 1/1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Touch Screen Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 2455LMT Touch Screen Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Touch Screen Replacement: 3 단계, 이미지 1/3 Garmin Nuvi 2455LMT Touch Screen Replacement: 3 단계, 이미지 2/3 Garmin Nuvi 2455LMT Touch Screen Replacement: 3 단계, 이미지 3/3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: 4 단계, 이미지 1/2 Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: 4 단계, 이미지 2/2
    • Locate the edge of the screen that fits into the plastic case
    • To separate the connector, gently push the tip of a spudger under the clip.
    • Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
  5. Garmin Nuvi 2455LMT Touch Screen Replacement: 5 단계, 이미지 1/1
    • Use the plastic opening tool to wedge between the plastic cover and screen.
    • Using your hands, gently push the front of the screen towards you to push the screen out of the casing.
결론
Torrance Williams
회원 가입일: 09/15/16
229 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 600
