주요 콘텐츠로 건너뛰기
Garmin Nuvi 2557LMT Disassembly
필요한 것
  1. Garmin Nuvi 2557LMT Disassembly, Garmin Nuvi 2557LMT Disassembly: 1 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Disassembly: 2 단계, 이미지 1/1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Disassembly: 3 단계, 이미지 1/1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Disassembly: 4 단계, 이미지 1/2 Garmin Nuvi 2557LMT Disassembly: 4 단계, 이미지 2/2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Danis Terzi
회원 가입일: 03/31/16
349 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 1,338
