주요 콘텐츠로 건너뛰기
Garmin Nuvi 2557LMT Motherboard Replacement
필요한 것
  1. Garmin Nuvi 2557LMT Motherboard Replacement, Garmin Nuvi 2557LMT Disassembly: 1 단계, 이미지 1개 중 1개
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Garmin Nuvi 2557LMT Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Motherboard Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the battery-motherboard connector away from the motherboard.
  7. Garmin Nuvi 2557LMT Motherboard Replacement, Speaker: 7 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, wedge the speaker from the device.
    • Don't pull it out of the device too far. It is still connected to the motherboard wire.
  8. Garmin Nuvi 2557LMT Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Using a soldering iron, desolder the wire connection between the speaker and the device.
  9. Garmin Nuvi 2557LMT Motherboard Replacement, Motherboard: 9 단계, 이미지 1개 중 1개
    • Using a T5 Torx Screwdriver, remove the 5mm screws in the four corners of the motherboard.
  10. Garmin Nuvi 2557LMT Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry the motherboard away from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Danis Terzi
회원 가입일: 03/31/16
349 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 566
