소개
The tools needed are T5 Torx Screwdriver and a plastic opening tool in order to get into the device. After that - your hands will be enough.
필요한 것
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
With the screen facing down, firmly grip the sides of the screen frame and pop the screen out.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
