주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Garmin Nuvi 255W Battery Replacement
필요한 것
  1. Garmin Nuvi 255W Battery Replacement, Power Button: 1 단계, 이미지 1/1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Battery Replacement: 2 단계, 이미지 1/1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Battery Replacement: 3 단계, 이미지 1/2 Garmin Nuvi 255W Battery Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Battery Replacement: 4 단계, 이미지 1/2 Garmin Nuvi 255W Battery Replacement: 4 단계, 이미지 2/2
    • Remove the power button.
  5. Garmin Nuvi 255W Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Battery Replacement: 6 단계, 이미지 1/2 Garmin Nuvi 255W Battery Replacement: 6 단계, 이미지 2/2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Battery Replacement: 7 단계, 이미지 1/2 Garmin Nuvi 255W Battery Replacement: 7 단계, 이미지 2/2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
결론
다른 15명이 해당 안내서를 완성하였습니다.
Timothy
회원 가입일: 01/26/12
73 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-3, Regan Winter 2012 Cal Poly, Team 9-3, Regan Winter 2012 회원
CPSU-REGAN-W12S9G3
5 회원들
안내서 4개 작성하였습니다
댓글 9개
Thanks for this very nicely illustrated guide.
RBStorms - 답글
Thanks for the guide. Used it to open up a Nuvi 265 because the battery had been left to discharge below the protection circuit's limit. Connected the battery leads (Green = ground, Red = voltage, Black = temperature) to a 5v USB charger for ~20 seconds to revive the protection circuit, and the unit is now charging again. If you're going to do this, know the risks. Thermal runaways in lithium batteries can be extremely volatile.
rbol - 답글
Used these instructions to replace battery in my 5-year old Garmin nuvi 205W (which has the same access and internal geometry).
JRedmond - 답글
Thanks, great demonstration.
peter2x4 - 답글
This is great! I have run into a big problem, though. One of the screws is "unthreaded." The head has become smooth, and I can't unscrew it to get the cover off. Is there any way to get it off???
nancyw - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 60
전체 시간: 26,667
