주요 콘텐츠로 건너뛰기
Garmin Nuvi 255W Logic Board Replacement
필요한 것
  1. Garmin Nuvi 255W Logic Board Replacement, Rear Casing: 1 단계, 이미지 1/2 Garmin Nuvi 255W Logic Board Replacement, Rear Casing: 1 단계, 이미지 2/2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 255W Logic Board Replacement: 2 단계, 이미지 1/1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 255W Logic Board Replacement: 3 단계, 이미지 1/2 Garmin Nuvi 255W Logic Board Replacement: 3 단계, 이미지 2/2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 255W Logic Board Replacement, Logic Board: 4 단계, 이미지 1/1
    • Peel away the tape holding the ribbon cable in place.
    • Disconnect the ribbon cable by using a spudger to flip up the retaining flap on its ZIF-style connector. Then gently remove the cable.
  5. Garmin Nuvi 255W Logic Board Replacement: 5 단계, 이미지 1/1
    • Pull out the cable between the logic board and the speaker to disconnect them.
  6. Garmin Nuvi 255W Logic Board Replacement: 6 단계, 이미지 1/2 Garmin Nuvi 255W Logic Board Replacement: 6 단계, 이미지 2/2
    • Remove the three screws from the logic board using the #00 Phillips screwdriver.
    • Lift the board away from the case but do not pull the logic board completely off, as it is still attached to the battery by a cable.
  7. Garmin Nuvi 255W Logic Board Replacement: 7 단계, 이미지 1/2 Garmin Nuvi 255W Logic Board Replacement: 7 단계, 이미지 2/2
    • Detach the logic board form the battery by pulling out the cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anjelica
회원 가입일: 04/11/10
564 평판
안내서 3개 작성하였습니다
Cal Poly, Team 25-90, Amido Spring 2010 Cal Poly, Team 25-90, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G90
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 13
30일 전: 26
전체 시간: 10,396
