주요 콘텐츠로 건너뛰기
Garmin Nuvi 255W Speaker Replacement
필요한 것
  1. Garmin Nuvi 255W Speaker Replacement, Power Button: 1 단계, 이미지 1/1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Speaker Replacement: 2 단계, 이미지 1/1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Speaker Replacement: 3 단계, 이미지 1/2 Garmin Nuvi 255W Speaker Replacement: 3 단계, 이미지 2/2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Speaker Replacement: 4 단계, 이미지 1/2 Garmin Nuvi 255W Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the power button.
  5. Garmin Nuvi 255W Speaker Replacement, Battery: 5 단계, 이미지 1/1
    • Unscrew the four 6.70 mm screws holding the motherboard in place using a philips #0 screw driver.
  6. Garmin Nuvi 255W Speaker Replacement: 6 단계, 이미지 1/2 Garmin Nuvi 255W Speaker Replacement: 6 단계, 이미지 2/2
    • Lift up the motherboard.
    • Carefully disconnect the battery and motherboard. Slowly wiggling the connection makes it easier to disconnect the battery from the motherboard.
  7. Garmin Nuvi 255W Speaker Replacement: 7 단계, 이미지 1/2 Garmin Nuvi 255W Speaker Replacement: 7 단계, 이미지 2/2
    • Using the plastic opening tool as a wedge, pry the battery from the case. This can be fairly tough as the battery is glued to the case. Don't be afraid to use force and some good leverage.
  8. Garmin Nuvi 255W Speaker Replacement, Speaker: 8 단계, 이미지 1/1
    • Carefully disconnect the speaker from the motherboard. Slowly wiggling the connection makes it easier to disconnect.
  9. Garmin Nuvi 255W Speaker Replacement: 9 단계, 이미지 1/2 Garmin Nuvi 255W Speaker Replacement: 9 단계, 이미지 2/2
    • Using a plastic opening tool, wedge the speaker away from the device. The speaker is glued to the case so use force and leverage.
결론
Timothy
회원 가입일: 01/26/12
73 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-3, Regan Winter 2012 Cal Poly, Team 9-3, Regan Winter 2012 회원
CPSU-REGAN-W12S9G3
5 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 3,964
