소개
If your device is not turning on you may need to replace a dead or faulty battery. Use this guide to replace the battery in your Garmin NUVI 2589 by completing the following replacement guide.
필요한 것
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Where can I buy this battery
Stan Levin
stan levin - 답글
where can I buy this battery
stan levin - 답글
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
