주요 콘텐츠로 건너뛰기
Garmin Nuvi 2595LMT LCD Screen Replacement
필요한 것
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: 1 단계, 이미지 1/1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 2595LMT LCD Screen Replacement: 2 단계, 이미지 2/2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: 3 단계, 이미지 1/3 Garmin Nuvi 2595LMT LCD Screen Replacement: 3 단계, 이미지 2/3 Garmin Nuvi 2595LMT LCD Screen Replacement: 3 단계, 이미지 3/3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1/2 Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: 4 단계, 이미지 2/2
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: 5 단계, 이미지 1/2 Garmin Nuvi 2595LMT LCD Screen Replacement: 5 단계, 이미지 2/2
    • Place new screen in proper position, with the ribbon facing downward.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Taylor DeWitt
회원 가입일: 01/06/16
538 평판
안내서 4개 작성하였습니다
댓글 3개
cannot prise open the connector to replace ribbon
norman bayne - 답글
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - 답글
Re-seating the ribbon is simply impossible.
daBee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 11
전체 시간: 4,588
