소개
This guide will help you replace your battery in a few short steps.
필요한 것
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 3개
Your sub-par tools broke when following the directions exactly. Last time I'll be purchasing any of your items, and Ill be disputing the charges on my card for this kit.
Thanks.
But before I get going, which model or type of battery do I need. Garmin does not seem to sell them separately as far as I can see.
GregM
Instructions very lacking. To replace the battery go to https://www.youtube.com/watch?v=OcoZC2Fk.... Much, much better instructions.
insert space between numerals and units (e.g., 4 mm).
Brian Blackburne - 답글
