소개
This guide will show you, in easy-to-follow steps, how to replace the LCD Screen. It seems like a lot of work, but don't worry because it isn't.
부품
지정된 부품이 없습니다.
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
