주요 콘텐츠로 건너뛰기
Garmin Nuvi 2797LMT LCD Screen Replacement
필요한 것
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: 2 단계, 이미지 1/3 Garmin Nuvi 2797LMT LCD Screen Replacement: 2 단계, 이미지 2/3 Garmin Nuvi 2797LMT LCD Screen Replacement: 2 단계, 이미지 3/3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: 3 단계, 이미지 1/1
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: 4 단계, 이미지 1/1
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
    the glass is cracked not the screen cover. now what
    Thomas L Camp - 답글
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: 5 단계, 이미지 1/2 Garmin Nuvi 2797LMT LCD Screen Replacement: 5 단계, 이미지 2/2
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: 6 단계, 이미지 1/2 Garmin Nuvi 2797LMT LCD Screen Replacement: 6 단계, 이미지 2/2
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
    i have a blank screen wondering if i didnt put the ribbon on correctly ive put it together a couple times same result hear a beep when first plugged in like normal but no screen any suggestions
    Frank Purvis - 답글
결론
다른 4명이 해당 안내서를 완성하였습니다.
baileykaytar
회원 가입일: 10/13/15
366 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 2-6, Blackburne Fall 2015 Sam Houston State, Team 2-6, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G6
3 회원들
안내서 4개 작성하였습니다
댓글 2개
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - 답글
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 7
전체 시간: 2,301
