소개
Here are a few easy steps on how to correctly remove the motherboard so a new one can be installed.
필요한 것
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 한 개
Do you know if there is any point on the motherboard where you could attach an external antenna? Or is the internal antenna removable to be replaced with an external or hacked to connect via a cable run to the outside of the device?
Did you happen to take a picture of the underside of the motherboard?
Thanks!
