주요 콘텐츠로 건너뛰기
Garmin Nuvi 2797LMT Motherboard Replacement
필요한 것
  1. Garmin Nuvi 2797LMT Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Before you begin make sure to turn off your GPS.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT Motherboard Replacement: 2 단계, 이미지 1/3 Garmin Nuvi 2797LMT Motherboard Replacement: 2 단계, 이미지 2/3 Garmin Nuvi 2797LMT Motherboard Replacement: 2 단계, 이미지 3/3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT Motherboard Replacement: 3 단계, 이미지 1/3 Garmin Nuvi 2797LMT Motherboard Replacement: 3 단계, 이미지 2/3 Garmin Nuvi 2797LMT Motherboard Replacement: 3 단계, 이미지 3/3
    • With the device opened, carefully remove the ribbon from the motherboard.
    • Unplug the three wire connectors from the motherboard.
  4. Garmin Nuvi 2797LMT Motherboard Replacement: 4 단계, 이미지 1/1
    • Using your T-4 Torx Screwdriver, unscrew six 1.58 mm T-4 Torx screws from the motherboard.
  5. Garmin Nuvi 2797LMT Motherboard Replacement: 5 단계, 이미지 1/2 Garmin Nuvi 2797LMT Motherboard Replacement: 5 단계, 이미지 2/2
    • Now remove the motherboard out of the device. You will have two separate pieces.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Isaias Silva
회원 가입일: 10/13/15
133 평판
안내서 1개 작성함
Sam Houston State, Team 2-6, Blackburne Fall 2015 Sam Houston State, Team 2-6, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G6
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Do you know if there is any point on the motherboard where you could attach an external antenna? Or is the internal antenna removable to be replaced with an external or hacked to connect via a cable run to the outside of the device?
Did you happen to take a picture of the underside of the motherboard?
Thanks!
Dragon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,222
