주요 콘텐츠로 건너뛰기
Garmin Nuvi 370 Microphone Replacement
필요한 것
  1. Garmin Nuvi 370 Microphone Replacement, Microphone: 1 단계, 이미지 1/1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nuvi 370 Microphone Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 370 Microphone Replacement: 2 단계, 이미지 2/2
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nuvi 370 Microphone Replacement: 3 단계, 이미지 1/2 Garmin Nuvi 370 Microphone Replacement: 3 단계, 이미지 2/2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nuvi 370 Microphone Replacement: 4 단계, 이미지 1/2 Garmin Nuvi 370 Microphone Replacement: 4 단계, 이미지 2/2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • This step is optional but is recommended as it will create more room to work.
    • It is recommended that you use tweezers or the spudger for precision.
  5. Garmin Nuvi 370 Microphone Replacement: 5 단계, 이미지 1/1
    • Gently pull out the microphone wire from the terminal. Tweezers are recommended for precision.
  6. Garmin Nuvi 370 Microphone Replacement: 6 단계, 이미지 1/1
    • The microphone component should now be completely separated from the motherboard.
    • Plug in new, functional microphone component.
결승점
Matt West
회원 가입일: 04/18/13
31 평판
안내서 4개 작성하였습니다
Cal Poly, Team 13-65, Johann Spring 2013 Cal Poly, Team 13-65, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G65
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 397
