소개
There are times when the power button might fall off the device. If that happens, refer to this guide in order to replace it.
필요한 것
Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
