주요 콘텐츠로 건너뛰기
Garmin Nuvi 50LM Power Button Replacement
필요한 것
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: 1 단계, 이미지 1/2 Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: 1 단계, 이미지 2/2
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: 2 단계, 이미지 1/2 Garmin Nuvi 50LM Power Button Replacement: 2 단계, 이미지 2/2
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: 3 단계, 이미지 1/2 Garmin Nuvi 50LM Power Button Replacement: 3 단계, 이미지 2/2
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Maurice Thomas
회원 가입일: 10/13/15
664 평판
안내서 5개 작성하였습니다
Sam Houston State, Team 2-7, Blackburne Fall 2015 Sam Houston State, Team 2-7, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G7
4 회원들
안내서 5개 작성하였습니다
댓글 3개
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - 답글
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - 답글
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 24
전체 시간: 6,859
