주요 콘텐츠로 건너뛰기
Garmin Nuvi 65LM Car Charger Fuse Replacement
필요한 것
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: 1 단계, 이미지 1/3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: 1 단계, 이미지 2/3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: 1 단계, 이미지 3/3
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: 2 단계, 이미지 1/3 Garmin Nuvi 65LM Car Charger Fuse Replacement: 2 단계, 이미지 2/3 Garmin Nuvi 65LM Car Charger Fuse Replacement: 2 단계, 이미지 3/3
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: 3 단계, 이미지 1/1
    • Turn the charger compartment over and carefully dump the fuse into your hand.
결론
Kai Ling Liang
회원 가입일: 04/26/15
246 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-3, Amido Spring 2015 Cal Poly, Team 15-3, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 2,069
