주요 콘텐츠로 건너뛰기
Garmin Nuvi 680 Antenna Replacement
필요한 것
  1. Garmin Nuvi 680 Antenna Replacement, Outer Case: 1 단계, 이미지 1/1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Antenna Replacement: 2 단계, 이미지 1/1
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Antenna Replacement: 3 단계, 이미지 1/1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Antenna Replacement: 4 단계, 이미지 1/2 Garmin Nuvi 680 Antenna Replacement: 4 단계, 이미지 2/2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Antenna Replacement: 5 단계, 이미지 1/1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Antenna Replacement: 6 단계, 이미지 1/2 Garmin Nuvi 680 Antenna Replacement: 6 단계, 이미지 2/2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Antenna Replacement, Antenna: 7 단계, 이미지 1/2 Garmin Nuvi 680 Antenna Replacement, Antenna: 7 단계, 이미지 2/2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
    The antenna ribbon cable has a latch that must be lifted first. It's a light muddy brown color. It flips up and away in the opposite direction of the ribbon cable.
    ewkpates - 답글
결론
Chris Marzano
회원 가입일: 01/20/11
968 평판
안내서 6개 작성하였습니다
Cal Poly, Team 5-22, Amido Winter 2011 Cal Poly, Team 5-22, Amido Winter 2011 회원
CPSU-AMIDO-W11S5G22
5 회원들
안내서 7개 작성하였습니다
댓글 한 개
Where can you find the replacment antenna?
All I see is external antennas on the net.
Dennis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 13
전체 시간: 4,453
