소개
A step-by-step guide to replacing the antenna in the Garmin Nuvi 680.
필요한 것
Flip open the antenna on the back of the device.
Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
Remove the antenna.
거의 끝나갑니다!
결론
