소개
For this guide you will be opening the device, but it is fairly simple. Before you begin disassembling the device, be sure the power is off.
필요한 것
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
거의 끝나갑니다!
결론
