주요 콘텐츠로 건너뛰기
Garmin StreetPilot c320 Rear Case Assembly Replacement
필요한 것
  1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: 1 단계, 이미지 1/2 Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: 1 단계, 이미지 2/2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Rear Case Assembly Replacement: 2 단계, 이미지 1/2 Garmin StreetPilot c320 Rear Case Assembly Replacement: 2 단계, 이미지 2/2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Rear Case Assembly Replacement: 3 단계, 이미지 1/1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
결론
Andrew Burman
회원 가입일: 01/18/12
1 평판
안내서 1개 작성함
Cal Poly, Team 11-19, Maness Winter 2012 Cal Poly, Team 11-19, Maness Winter 2012 회원
CPSU-MANESS-W12S11G19
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,369
